Subwoofer and amp with stock radio - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 14 (permalink) Old 04-04-2009, 01:56 AM Thread Starter
Is there a way to hook an amp and subwoofer up to the stock radio head unit in an 07 SR5? If there is, what do I need to do it? I pulled out the radio today and it looks like it has an extra place to connect something in the back, but nothing is there, is that for an amp? I asked someone at an auto place store and they said that I need to get some kind of splitter and run an AUX cable all the way to the amp, is that true? If it is, where can I get the splitter?
Brandon772 is offline
post #2 of 14 (permalink) Old 04-04-2009, 03:18 AM Thread Starter
Would something like This work? It says 80 watts. Will that affect the watt output of the amp? If it is a 2000 watt amp and i use that converter, will the amp still put out 2000 watts? And can that converter just be wired right in with the rear speaker, and the speaker still work? Also, where does the "remote" wire go on the stock head unit?
post #3 of 14 (permalink) Old 04-05-2009, 01:35 AM
kit
kit's Avatar
Quoted: 23 Post(s)
I'm not a car audio expert. But I think that is the adapter needed, and the wires need to be crimped with the existing wires you have plugged into to your stock head unit. But I'm not positive.
kit is offline
post #4 of 14 (permalink) Old 04-05-2009, 04:52 PM
Beerguy's Avatar
Quoted: 26 Post(s)
You can always turn the amp down to compensate for any amp that is in the radio.
You will need line level converters so you can hook the speakers up to the amp. That is unless your amp has line level input connectors. You will need extra speaker wire and RCA cables.
The "remote" wire just needs to be hooked to the accessory power circuit. This way your amp(s) don't stay on when you shut the truck off.
Beerguy is offline
post #5 of 14 (permalink) Old 04-05-2009, 05:12 PM
KrytikalMedic's Avatar
The easiest way to accomplish this is by adding a line-out converter. It piggybacks off of your speaker wires and turns it into a set of RCA plugs. Then all you have to do is run and RCA cable to the input of your amp. I know this because this is what I have to do before I install my amp in my SR5 DC.
KrytikalMedic is offline
post #6 of 14 (permalink) Old 04-05-2009, 05:14 PM
The "adjustable" feature of the line out converter is to adjust the signal coming from your head unit. This does not effect your amp, but more so "how much" of the signal going into it. Yes, this wire piggybacks off of the speaker wires and the speakers work just fine.
The Following User Says Thank You to KrytikalMedic For This Useful Post:
osanchez637 (03-14-2014)
post #7 of 14 (permalink) Old 04-05-2009, 05:19 PM
while the preferred method is to run the RCA's directly off of your head unit, but you will get a "good" sound quality even from tapping into your speaker wires w/ the convertor.
ShaneinATL is offline
post #8 of 14 (permalink) Old 04-06-2009, 12:05 PM
w0t kind of equipment are you going to run?
doughboi916 is offline
post #9 of 14 (permalink) Old 04-06-2009, 08:42 PM
SP
Moderator
SP's Avatar
Quoted: 372 Post(s)
this is a waste of time and money. I know beacuase I did it. the bass that the OEM deck puts out is horrable. You can try it though. The oem radios are delphi or panasonic. I think if you have the panasonic deck you will have a better chance. I had the Delphi in my 08 and it sounded like ass.
I tested this with a Powered 6" bazooka that I have been using for the last 3 vehicles. It sounded 10X better in every factory setup BUt the tundra.
2014 CM 5.7L 1794 edition
Front tint*OEM look alike Brushed steps*GENSSI® ELITE G7 H4 Led's*morimoto LED fogs(excellent)*interior canbus LED's*Husky Floor Liners*Trd Pro grill and color matched front end*TRD sway bar*LowPro Rollup Tonneau cover*20 inch Black Rhino black wheels*Sotck nit size terra graplers*Bully Dog tuner AWESOME*
SP is offline
post #10 of 14 (permalink) Old 04-09-2009, 09:01 AM
maddawg's Avatar
I used the infinity Basslink 10" powered sub in my Jeep now and it sounds Great might wanna give it a go!
maddawg is offline
post #11 of 14 (permalink) Old 04-16-2009, 05:57 AM
kit
kit's Avatar
Quoted: 23 Post(s)
So did you get it hooked up brandon? How was the install if you did it already?
kit is offline
post #12 of 14 (permalink) Old 04-16-2009, 10:18 AM
fishin guy's Avatar
It should work fine. I've done the same thing in a couple of my previous vehicles. I plan on buying either two 10's or one 12 and putting it in my new Tundra with the stock radio for now.....
2008 Tundra CrewMax 4x4
Blue Streak Metallic / Black Interior
- 3 / 1.5 Rough Country Leveling Kit
- Black 18x9 XD Monster Wheels +35 Offset
- Weathertech DigitalFit Floor Mats (Black)
Best saltwater fishing jigs!
fishin guy is offline
post #13 of 14 (permalink) Old 04-16-2009, 10:21 AM
fishin guy's Avatar
I think that 6" speaker may have had something to do with why it "sounded like ass." A 6" speaker isn't going to do much.
post #14 of 14 (permalink) Old 04-16-2009, 01:36 PM
"Seńor Member"
SybErkRimInAL's Avatar
that extra port can be used to add satellite radio or even an ipod adapter.
SybErkRimInAL is offline
