8" pioneer Under Seat Install. Help! - TundraTalk.net - Toyota Tundra Discussion Forum
Old 01-03-2013, 05:26 PM   #1 (permalink)
TORocket15's Avatar
Question 8" pioneer Under Seat Install. Help!
I didn't want to high jack a thread so here's a new one.
This was the original thread Pioneer 8" sub in DC under seat storage
I love this install and I have been planning on doing it for a long time and I finally have everything to do it thanks to Santa.
I am currently doing this mod and I am posting here because I am fairly new with this stuff and WILL NEED HELP! I will have more specific questions when I reach certain points in the install.
Things I have:
8" pioneer sub
Rockford Fosgate P300-1 Amp
Punch Equalizer Remote to adjust the sub output that I plan on installing into one of the blanks in the dash.
PAC SNI-35 Adjustable line output converter
Sound quest amplifier wiring kit SQ600XS
1/2" MDF
Poly Fill
I will try to post pics during the process.
TORocket15 is offline   Reply With Quote
Old 01-03-2013, 05:36 PM   #2 (permalink)
TORocket15's Avatar
Finished tasks:
Build sub box for underseat storage
Paint sub box
Dremel a blank and install amp power level dial
Read instructions for wiring
Feel intimidated
most daunting task remaining:
Wiring!
Alright so there's two parts I know I need help with now.
1. How to wire the amp to a sound source.
2. How to get the power cable from inside the cab to the battery.
I'm worried I'm really gonna screw something up if I don't ask.
I'll post pictures of the box and the switch when I get home.
Old 01-03-2013, 05:50 PM   #3 (permalink)
Originally Posted by TORocket15 View Post
Finished tasks:
Paint sub box
Feel intimidated
Wiring!
For the amp to battery, run the cable from the amp, down the battery(left) side of the truck through the interior panels, they should just pop off except for the panels with seat belts which have to be unbolted, then run the cable through the firewall (I carefully cut a hole in the rubber grommet with the wires coming in through the wall) and run it to your battery. Also, what do you mean by amp to a sound source? Head unit or sub?
'08 DC SR5 TRD 5.7L | LRO 3/1 | 5% Tint All Around, 35% Windshield | Orion HCCA 12.2 | AFE CX | Dual 26x2.25 Powersticks |
nps3928 is offline   Reply With Quote
The Following User Says Thank You to nps3928 For This Useful Post:
TORocket15 (01-04-2013)
Old 01-04-2013, 03:46 AM   #4 (permalink)
TORocket15's Avatar
the head unit
Old 01-04-2013, 04:32 AM   #5 (permalink)
Moderator
Slate CrewMax's Avatar
To get the sound to the amp, you could use the speaker wires coming from the back of the HU. You could also grab the acc wire for the amp turn on. I have the colors on my work computer if you need them, but they are readily available on line.
nps3928 is right about the power wire, although I would not worry about removing all the panels. You can usually just push the wire under them without removing.
Slate CrewMax is online now   Reply With Quote
The Following User Says Thank You to Slate CrewMax For This Useful Post:
TORocket15 (01-07-2013)
Old 01-07-2013, 04:45 PM   #6 (permalink)
TORocket15's Avatar
Where can I find the diagrams online?
By the way thanks for all of the help
Old 01-07-2013, 09:42 PM   #7 (permalink)
Moderator
Jumbo Jet's Avatar
Run the power wire from the battery, through the firewall at the rubber pass thru. You can mount the fuse on the side wall of the engine compartment or I've seen a few guys just stick it on top of the main fuse box.
On the bottom of the pass thru is a small rubber nipple. It's empty, so you can cut the tip of it off and pass the power wire through there.
And a mounting location for the fuse. Again, some guys have just mounted it to the main fuse box lid. The power wire is wrapped with tech-flex for protection.
The power wire will come through right above the brake pedal. From there you'll feed it down the drivers side channel underneath the door sills to the rear or where ever your amp is.
I'd recommend running at least 4awg wire, or bigger. That will also help future proof any upgrades.
Jumbo Jet is offline   Reply With Quote
TORocket15 (01-08-2013)
Old 01-07-2013, 10:29 PM   #8 (permalink)
Mr Fabrications's Avatar
Amp,XM and sub all under rear seat fits perfect and sounds even better
2008 Tundra SR5 Double Cab
CST Spindle's
CST Rear Shocks
CST 1.5 Blocks
Icon Coil-overs
Icon Uni-Ball UCA
Street Taco +3 Shakals
Street Taco Drive Shaft Drop 1.25"
RBP 94R 18x10 0 Offset
Mr Fabrications is offline   Reply With Quote
Old 01-08-2013, 12:59 AM   #9 (permalink)
Moderator
You don't have the JBL system, right?
Old 01-08-2013, 09:14 AM   #10 (permalink)
TORocket15's Avatar
Non-JBL system.
Old 01-08-2013, 09:15 AM   #11 (permalink)
TORocket15's Avatar
Thumbs up
Nice!
Old 01-08-2013, 09:26 AM   #12 (permalink)
TORocket15's Avatar
Current Progress
This is how far I am right now. Just have to mount the amp and wire it up. Thanks everyone for the huge amounts of help. I'll try to put up a step by step for the wiring.
Built the box, sprayed on some textured paint, installed the wiring terminal, and filled with polyfil.
Dremeled out a blank and installed this adjustable output knob for the sub. Hooks right up to the amp.
Old 01-09-2013, 04:26 PM   #13 (permalink)
TORocket15's Avatar
HELP! I don't know which wires are which
Not sure which wires are to the left and right speaker on the back of the stereo.
Old 01-09-2013, 05:14 PM   #14 (permalink)
Moderator
Jumbo Jet's Avatar
Bass knob looks great there. Nice work.
Old 01-11-2013, 09:26 AM   #15 (permalink)
TORocket15's Avatar
Talking Finished!
Success! Can't tell you how happy I am that this all went smooth because it was done the correct way with the help of everyone on here! Thanks Tundratalk!
Here are some of the pictures I took during the process.
Wired the converter to the rear speakers. I actually paid someone $30 to wire it up because I could not find ANYTHING that explained which wires are which back behind the stereo. But they did a good job and it works great.
Ran the wires way back there.
Where the wires ended up.
Getting the power wire through to the engine compartment was a pain. I used that same spot mentioned by Jumbo Jet earlier. It worked out but it was tough to move around in that tight space. Also took off all the panels to run the wires through including the door sills, front panel under the dash, and Both seatbelts panels.
Decided to put the amp under the other seat. I may move it later but it's fine for now. It is not comepletely wired up in this picture.
Attached the fuse directly to the fuse box lid.
