AUX input?
16K views 9 replies 7 participants last post by  KF8DLD
#1 ·
I just recently purchased a 07 DC 4x4 and the previous owner tore up the AUX input. I asked the dealer today what a new one would cost and was told $115. I noticed the 2010 models also have a USB above the AUX plugin. Has anyone tried to install a 2010 model AUX in a earlier model?
#2 ·
Welcome to the forum! Don't forget to introduce yourself in the new member section.
never heard of this being done. I would say the aux would work but the USB wouldn't because the 07-09 probably isn't prewired for the USB. I am not sure, just guessing that it isn't. I have never pulled out my radio so I am not sure how that ties in to the radio. I am sure someone here has though.
#3 ·
You won't get USB functionality without also changing the head unit out.
If you don't care about having a factory-looking AUX port and just want an electrically functioning one, just buy any panel mount 3.5mm TRS female connector with plug insertion detection (should have 4 contacts) for $5 or less and put it into one of the blank spaces beside it (if there are any). Wire it appropriately. I can dig up the wiring diagram if you are interested in that.
#4 ·
trent, im not sure if that would allow ipod control through the h-u n steering wheel or not.
may be interesting tho.
#9 ·
That is right, there is no device control capability with just wiring for analog audio.
I suggested the cheap solution because it is a technically functioning solution, like with the info buttons. I don't believe in paying close to $100 for a OEM branded audio jack unless it does something no other component can do.
I answered the question by stating that USB will not be possible without changing the head unit, then kinda strayed off that and suggested a normal 3.5mm female jack with plug insertion detection.
From what I read, the problem is that the vehicle once had a working AUX port as they all do, but the mechanical connection is having issues.
I'm not sure where the iPod-specific thing was brought up or why it is relevant to this. :confused: Any analog audio source will work with the auxiliary input.
#5 ·
I thought about just doing a different one and wiring it in also. I just Wanted something to fill the hole back in and not have that ugly opening. I talked to my buddy at my local audio shop and they have something that will wire to the factory headunit and give me ipod capapabilities along with charging for around $80 which is cheaper than the $115 i was quoted at the dealer for just the 3.5 aux input. The only Problem with that is we have an ipod/iphone hook up in our 02 wrangler but it wont charge the 4th gen ipod touch or the iphone 4 thanks to Apple changing the pin connector or something. Well with the iphone 5 coming out within prolly the next 1-1.5 yrs I hate to buy either the $85 connector or the $125 connector. So maybe i should just wire in a $5 aux input for now and see what happens.
#8 ·
If you are talking about the AUX and not the USB port your truck should've came with it from the factory. Mine came with it and I plug my phone into it for music and it makes my phone go crazy and shuts it off, I don't know about iPod's though.
#10 ·
2013 aux input capacity
Does the 2013 input capacity?? I want to take the 2w output from my Amateur Radio and plug it into the Aux input on my Tundra so I can get the radio output through the vehicle speakers. But, I don't want to damage it by over loading the circuit.
Thanks
73
Dale
KF8DLD (Grid EM15IM58KV )
Amateur Radio Relay League (ARRL)
Edmond Amateur Radio Society (EARS)
