Rear blocks VS. Add A Leaf
I am looking at the Toytec 3'' Lift in the front and 1'' in the rear....wondering which should i go with? The rear blocks or the leaf? I do tow my ATV Trailer alot like once a week. Its only about 2000lbs or so loaded tho. Once and awhile i do get a ton of wood pellets......which i think the added leaf would help in that. But thats not somethin i do everyday. Once and awhile i will tow a 5000-6000lbs trailer but thats not very often.
The AAL will make the ride more rough
The blocks will keep the same ride but may increase axle wrap 1" isnt that bad I would do the front end first and see if you even need the rear
Seriously its not that big of a difference. Unless one is like $100 cheaper go with that one. But they will do the same for you. I'd get AAL for payload (a little stiffer not much) or it you want stock ride blocks.
Either way they will be fine. |
I went with the blocks on mine , as I don't tow anything normally . It does ride a little rougher than stock at times , but nothing huge .
#12 (permalink) |
Just raise the door header and get a roll down type door. I've seen it done with no problems. Or you can build a carport like I did.
#14 (permalink) |
OK I just don't understand. I have lifted several trucks in my lifetime. Ford, Nissan, Chevy, and soon to be Toyota.
On every forum I have been on, and at every off road shop I have been to, I have been told that blocks or AAL are the best because they DO NOT cause axle wrap like shackles do. And that Blocks maintain the best factory ride because AAL will stiffen up the ride so much. What is different about the Tundra that makes the blocks cause axle wrap? |
#15 (permalink) | |
SAS Tundra |
