Needing a new rear end - Need Some advice - TundraTalk.net - Toyota Tundra Discussion Forum
Old 06-22-2012, 03:13 AM   #1 (permalink)
Another member recently posted a video of a noise his truck was making. Turns out its the same noise I'm dealing with, except I'm out of warranty. The dealer says a tooth broke off of the gear and ended up replacing the whole rear diff assembly. Out of warranty cost a little over $3000.
So my question is, what are my options for upgrading. I do plow snow, I do pull a 4,000lb trailer at least once a week, and I do a little bit of offroading and am tired of the one-wheel peel.
To start, I know nothing about rear ends. I can do a fluid change and thats about it. I've researched a little on here about auburn LSD's, ARB Air Lockers (I already have an air horn setup), and the famous 4.88 gears available (35 x 12.5 tires coming this fall). But this truck is my DD, so 4.88 gears scare me a little with gas mileage.
What are my best options, aftermarket or OEM. If the cheapest way is to spend the $3000 and get the toyota parts, I guess thats my answer. But if I can get a locker for $3000, why not? May as well upgrade while its getting replaced. I don't want to end up spending the $3000 for the toyota parts and $1500 more for a LSD or locker.
I'm just looking for a list of options, as I have no clue what I am looking at. Install would be done at a local offroad shop, since I am not ready to tackle this project.
Sorry for the rambling post but thanks in advance for the help!
-Austin
15.037 @ 92.87MPH
2007 Black TRD SR5 4x4 DC
5% tints all around. XDI intake.
295/70/18 Nitto Trail Grapplers
8000k HID's in headlights and foglights.
Dual 2.5" x 26" Powersticks/QTP Electric Cutouts
Hornblasters 540 Kit
Low Range Offroad 3/1 Leveling kit
dothedeww is offline   Reply With Quote
Old 06-22-2012, 04:19 AM   #2 (permalink)
rockstate45's Avatar
A bit tired here, but if you went with the 4.88s you might not hurt fuel economy with the larger tires.
Effectively, your 4.30 gear ratio with a 295/70/18 Nitto is gnna be somewhere in the high 3s numerically.
Going to a 4.88 might give you the equivalent of a 4.30, and may offer a little low end torque too.
Not sureif you need a hypertech there or not.
-rockstate
rockstate45 is offline   Reply With Quote
Old 06-22-2012, 01:22 PM   #3 (permalink)
-rockstate
Thank you!
Now I just need someone to chime in with prices so I know how much I need to fork out!
And I would probably get the hypertech to be safe.
15.037 @ 92.87MPH
Old 06-22-2012, 01:28 PM   #4 (permalink)
The 4:88's are for two wheel drive trucks; no matching ratio for the front differential
'07 DC SR5 Tundra 4x4
Pyrite Mica
Under seat storage box
Tow package
Cold package
Tekonsha Brake control
Brushed stainless sidesteps
TRD alloy wheels/Goodrich POS tires
Steel wheels/Cooper Discoverer S/T studded snows(4)
Toyota box liner-soon to be Line-xed
X-Tang tonneau cover
Bone stock and staying that way
oldtimer is offline   Reply With Quote
Old 06-22-2012, 01:30 PM   #5 (permalink)
They mention the front here
4.88 Ring & Pinions for 2007+ Toyota Tundra & Landcruiser 200series! - New Products - Nitro Gear & Axle
15.037 @ 92.87MPH
Old 06-22-2012, 01:43 PM   #6 (permalink)
Oops, sorry. These must be relatively new, as I was under the impression there were no aftermarket gears available for the front differential
Pyrite Mica
Tow package
Cold package
Old 06-22-2012, 01:45 PM   #7 (permalink)
I think new as in October of 2011, so yes very new still.
I would love to have that extra low end torque, I just want some pricing quotes here. haha
15.037 @ 92.87MPH
Old 06-22-2012, 01:47 PM   #8 (permalink)
LMartz's Avatar
If its just a gear, why not take it to a shop and have the truck re-geared?
Are the axles in good shape still?
2012 Magnetic Gray Crewmax, 5.7 liter 4x4: 7" BDS lift, Fox coilovers, 37" Toyo Open Country M/Ts, 20" BMF Death Metal Novakane 5s, BMF Death Metal grille, LEER 550 Tonneau, AMP PowerSteps, Roadwire leather interior, Magnaflow exhaust
AZ Tundra Club Member #5
LMartz is offline   Reply With Quote
Old 06-23-2012, 01:18 PM   #9 (permalink)
I believe its just the gears but I'm really not sure.
The other member took it to toyota and they replaced the whole rear diff assembly.
How do I check the axles?
Thanks,
Austin
15.037 @ 92.87MPH
Old 06-23-2012, 08:12 PM   #10 (permalink)
krewmaxxed's Avatar
Xtremelow is the other member who just got his fixed. You should send him a pm, I think he was trying to get more info on his from the dealer
I CANT LEAVE WELL ENOUGH ALONE!!
krewmaxxed is offline   Reply With Quote
Old 06-24-2012, 04:34 AM   #11 (permalink)
Three grand should get you both front and rear air lockers and new gears installed as long as the axles are good. Go price everything at Just Differentials. They are a supporting vender here so PM the sales guy who deals with this forum and see if he can work a deal out with you. From what I have hard install should be about $600- $700. If the axles are bad find some from a truck that was hit head on from a junk yard. Get everything installed at a shop that specializes in axles and diffs.
I would tell Toyota to shove it, take it to a rear end shop and get something above and beyond what Toyota is trying to get you to buy for a better price.
jemplayer is offline   Reply With Quote
The Following User Says Thank You to jemplayer For This Useful Post:
cosanostra (12-30-2012)
Old 06-25-2012, 01:53 PM   #12 (permalink)
Esactly how I feel. I will contact Just Differentials and see what we can work out.
As just to be clear, I didn't get the price from toyota, this is from another member who had his rear end replaced under warranty, and they told him the cost if he was not under warranty.
Still, for that price this truck better be beefed up.
Thanks!
Austin
15.037 @ 92.87MPH
Old 06-27-2012, 01:14 PM   #13 (permalink)
So I unscrewed the fill plug today to check out the fluid...
This is the stuff that drained out when I took the fill plug out...
Remember..only 30k on this Royal Purple Synthetic.
And it is veryyy sparkly. its hard to tell from the phone pic.
15.037 @ 92.87MPH
Old 06-27-2012, 01:33 PM   #14 (permalink)
1stYoda's Avatar
If that drained out of the FILL plug, I can only imagine what will come out when you pull the drain plug. I see a new gearset at a minimum in your near future unfortunately. How much abuse, if any, has that rear end seen?
NRA Endowment Member
1stYoda is offline   Reply With Quote
Old 06-27-2012, 01:38 PM   #15 (permalink)
exactly what I am thinking, I do not want to drain the bottom plug.
And I am waiting for it to go and then new gears are coming, hopefully 4.88's!
and the rear end has seen some abuse, its been 120k miles. I mean I go in 9inch deep mud maybe twice a year, and I love doing donuts in the snow. And the truck has done maybe 5 short burnouts in its entire life. I do pull heavy trailers (9000+) every couple months, but I am easy and always in tow/haul mode.
So I don't consider that too much abuse, more than the average sunday driver, but not to the extent some guys abuse the rears.
15.037 @ 92.87MPH
The Following 2 Users Say Thank You to dothedeww For This Useful Post:
1stYoda (06-27-2012), riccnick (12-04-2012)
