Needing a new rear end - Need Some advice - Page 4 - TundraTalk.net - Toyota Tundra Discussion Forum
Old 01-02-2013, 11:39 PM   #46 (permalink)
Bennett22's Avatar
Originally Posted by dothedeww View Post
I am sorry guys I havent been on TT in a bit.
This second time was indeed the rear most ujoint failing. I replaced all 3 while I had the driveshaft out.
Sorry for the confusion and pre-diagnosis of the rear end failure.
In my first rear I have only Toyota fluid in it. I changed it every 50k. I only switched to royal purple when it began to fail to try and fix the issue.
In my new rear I am using mobil 1 synthetic 75w-90. I had heard good things about it. The new rear is still in good shape and does get abused time to time.
I have added a pic of the ujoint cap from the rear most ujoint. I crawled under the truck and could not move the driveshaft at all so I assumed it was not a ujoint. I couldnt tell the ujoint was bad until I removed the driveshaft. My friend who has been a pro mechanic for 45 years checked it and didnt find any play in the driveshaft either.
Also, I do grease the ujoint every oil change. Each time they are nearly empty. Everyone should check theirs! I replaced the old ujoints with napa heavy duty ujoints.
Thanks for the help!
Austin
Sent from my Galaxy Nexus using AutoGuide.com App
whew!!! thats one f**ked ujoint.i haven't seen anything that on a pick-up,seen it plenty of times when i was working on heavy duty trucks and the guy would drive in saying he some sort of clunking sound when he started driving,lol.i'm actually surprised they didn't fail sooner with the mileage you have and the fun you've had with the tundra.
2012 Crewmax 4X4 SR5 TRD 5.7L Silver Streak Metallic - Purchased 5/23/12
2008 DC 4X4 SR5 TRD 5.7L Blue Streak Metallic - Traded in 5/23/12 with 72,325mi - It was fun while it lasted
13+ years with heavy duty wrenching(95% diesel work)
Detroit Diesel/FRTL/Cummins trained
GO YANKEES!!!!!!!
http://www.dimartinomotorsports.com/
http://www.facebook.com/#!/pages/Dim...88616001165001 vinnie - formerly of orange county choppers
Bennett22 is offline   Reply With Quote
Old 01-02-2013, 11:46 PM   #47 (permalink)
Yeah it was pretty messed up. But I have had plenty of fun with my truck.
The weird thing is, the noise started on a friday. I towed a car out of state on Saturday, the noise got horrible on Monday, and I changed it thursday. It didnt give much warning. I had one go bad on our ram 1500 and drove it for probably 6 months with it squeaking before we replaced it.
15.037 @ 92.87MPH
2007 Black TRD SR5 4x4 DC
5% tints all around. XDI intake.
295/70/18 Nitto Trail Grapplers
8000k HID's in headlights and foglights.
Dual 2.5" x 26" Powersticks/QTP Electric Cutouts
Hornblasters 540 Kit
Low Range Offroad 3/1 Leveling kit
dothedeww is offline   Reply With Quote
Old 01-03-2013, 10:46 AM   #48 (permalink)
The metal housing unit on the right has a gouge in it (the first picture posted), how did it get there? Did you hit a rock?
2011TundraInMe is offline   Reply With Quote
Old 01-03-2013, 10:54 AM   #49 (permalink)
I saw that too. I honestly have no idea.
15.037 @ 92.87MPH
Old 01-03-2013, 11:48 AM   #50 (permalink)
My thought is the cause may have lead to the u-joint failing.
Old 01-03-2013, 01:02 PM   #51 (permalink)
That is very true, I never thought of that
15.037 @ 92.87MPH
Old 01-05-2013, 02:32 PM   #52 (permalink)
Bennett22's Avatar
yes,the wear on the cap on the right side of the pic is from where it was rubbing the joint itself without any lube or needle bearings.i've seen worse,as in a truck only coming in with half a cap or none at all,but that is bad.
GO YANKEES!!!!!!!
