Supporting Vendor
December Special: 1/4" Steel Tundra Leveling Kit - $94.99!!
THINKING OF BUYING A POLYURETHANE LEVELING KIT? READ THIS AD FIRST !! These have just been released and are already being used by dealers because of their MANY advantages!! This is a brand new "patent pending" leveling lift kit for the 2007-2008 Toyota Tundra 4 wheel drive AND 2 wheel drive. These will lift the front of your truck approx. 2.25". These are manufactured in house by Top Gun Customz. THESE TAKE AS LITTLE AS ONE HOUR TO INSTALL !!
FEATURES OF OUR KIT!
The highest quality materials are used including zinc plated hardware and nylon-locking nuts. Because these are so unique and easy to install, they are "patent pending". Pictured is a customers 07' Tundra with our leveling kit and stock wheels and tires. 4wd's can clear up to a 33" tire with ease. SEE IT TO BELIEVE IT !! BEFORE: ![]() AFTER: ![]() Here is a picture of the spacer and a picture of a spacer mounted on a Tundra strut. ![]() ![]() With polyurethane kits, a spacer is installed BETWEEN the coil spring and the top of the strut. That puts preload on the spring which noticeably stiffens up the ride. But probably the worst thing about the poly kits is they are known for over-extending the strut causing strut failure. With ours, you simply unbolt the strut from the vehicle, install the steel spacers on top of the strut and bolt everything back up. RIDE QUALITY IS UNCHANGED UNLIKE THE OTHER KITS ON THE MARKET. This kit does wonders for the look of your new truck. It is recommended that you have the alignment checked after installation. This kit comes with all hardware which is zinc plated and complete instructions. The spacers are offered in black finish. As a December special, Order this kit for $94.99!! Call us today at: 1-877-274-9362 This is the most affordable and indestructable leveling kit on the market for your brand new Toyota Tundra!! ![]() |
