Originally Posted by Rob S.
Cool, will do.
So new antenna and new color matched door handles will be the mod planned for this weekend. Are the handles easy to do? Will the door panel come of easly?
JC is on top of it .. its very simple
open the door, you will see a round black tab
pop that off with a flat head
inside you will see a torx screw .. unscrew it all the way (dont worry about dropping it, there is a small tab and it wont fall)
after that, you just slide out the small piece of the handle, then slide the large part towards where the small part was and it will slide free.
dont worry if you have to use a little bit of force .. you wont break it
have fun
