Which Deal to take?
Hello First time poster and looing fo your insights, I'm being offered a deal by two dealers here are the numbers, would that be the price to pay? or are they sending me to the cleaners?:
Model Description: CMAX LTD 5.7L V8 Category ..........: G Year ...........: 2007 Interior Color ..: LB13 LB13 Wholesale Dealer ..: Exterior Color ..: 01F9 SLATE Previous Dealer ...: Body ............: CMAX LTD 5.7L V8 Invoice Date ......: 05/24/07 Number of Cyl ...: 8 Ship Date .........: 05/29/07 Allocation Number: 041 Retail Date .......: Engine Number ...: 5053789 Date of First Use .: Vessel Number ...: 719 TRAC ..............: NO Vessel Name .....: TMMI PRINCETON Damage .: NO DAMAGE PDI ...............:YES Fleet .............: Factory Installed Accessories: FE CK AL MG RL SO SR Port Installed Accessories ..: BL Z2 Retail Dealer Total Vehicle Base Model ...............................$ 38790.00 $ 33940.00 $ 38790.00 50 State Emissions ......................... Cold Kit: Heavy Duty Battery, ...................100.00..........80.00 Starter, Heavy Duty Anti-Corrosion ......... Protection, Windshield Wiper De-icer ....... w/Timer ................................... 20" Alloy Wheels w/P275/55R20 Tires ...........920.00......736.00 Front and Rear Mudguards ...........................60.00.......48.00 Daytime Running Lamps ...............................40.00.......32.00 Front and Rear Clearance Sonar ..................500.00......400.00 Power Tilt and Slide Moonroof .....................810.00......648.00 Bedliner with Deck Rail System ....................345.00......195.00 Preferred Accessory Package ......................256.00......157.50 .................................................. .......-----------...---------..--------- Total Accessories ..................................$.3031.00...$.22 96.50...$.3031.00 Destination Charge ..................................$..645.00.....$. ..645.00 TDA .................................................. ......................$ 849.00 Gasoline .................................................. .................$ 10.00 Dealer Holdback .................................................. .......$ 775.00 Whsl. Financial Reserve ...............................................$ 387.00 .................................................. ...........................--------- --------- Total .................................................. ................... $ 38902.50 $ 42466.00 Plus the $4000.00 Rebate OR this other Deal that hasn't beeing built yet: 18186 VEHICLE INQUIRY REPORT DATE: 02/12/08 CV920 TIME: 13:40 Model Number: 8262A SERIAL # :8X11C692 Check Code: 9 Model Description: CMAX SR5 5.7L V8 Category ..........: A Year ............: 2008 Current Dealer ....: Interior Color ..: FL13 FL13 Wholesale Dealer ..: Exterior Color ..: 01D6 SILVE Previous Dealer ...: Body ............: CREWMAX 5.7L SR5 Invoice Date ......: Number of Cyl ...: 8 Ship Date .........: Allocation Number: 021 Retail Date .......: Engine Number ...: Date of First Use .: Vessel Number ...: 711 TRAC ..............: NO Vessel Name .....: TMMTX SANANTONIO Damage ............: NO DAMAGE PDI ...............: NO Fleet .............: NON-FLET Port PDS Complete .: NO VIN .............: Ignition Key.....: Factory Installed Accessories: FE RL SO SP ST TM Port Installed Accessories ..: LU 2Q .................................................. ...Retail Vehicle Base Model ....................: $ 30935.00 Total Accessories .....................: $ 1054.00 MECHANICAL & PERFORMANCEGVWR = 7000 lbs. Payload = 1605 lbs. 381HP/401 Lb-Ft 5.7L DOHC 32V iForce V8 w/Dual Independent VVT-I and ACIS 6-Spd Auto w/Seq Shift and Tow/Haul Mode Engine Immobilizer, Cruise Control Tow Equip/Capacity: Tow Cap=10,400 lbs. Hitch Receiver, Supp A/T Cooler, 4.30 Rear Diff w/10.5" Ring Gear, 150A Alternator, A/T Temp Gauge, 7 Pin Conn,Trailer Brake Controller Prewire Automatic Limited Slip Diff (Auto LSD)Triple Tech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors Multi-Leaf Trapezoidal Rear Suspension 18" Styled Steel Wheels P255/70R18 Tires Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors EXTERIOR Double-Walled Bed w/Tailgate Assist Black Handles, Pwr Htd Outside Mirrors Chrome Grille Surround, Fr & Rr Bumpers Pwr Vertical Rr Window w/Privacy Glass INTERIOR Cloth Buckets w/8-way Pwr Adj Drvr-sideTilt/Telescoping Steering Wheel Slide and Recline 60/40 Rear Bench Seat Dual Zone Climate Control w/Sync Mode AM/FM/6-CD w/6 Speakers & Aux Audio Jack Center Console w/Laptop & File Storage Power Windows/Door Locks/Mirrors Remote Keyless Entry System Variable Intermittent Windshield Wipers SAFETY STAR Safety: Pwr Assist 4 Wheel Disc ABSw/Electronic Brakeforce Distrib (EBD), Brake Assist, Vehicle Stability Control with Traction Control (VSC+TRAC)Dr & Fr Pass Advanced Airbags/Seat Side Airbags/3 pt Seatbelts w/Pretensioners & Force Limiters Roll-Sensing Curtain Airbags (RSCA)T ire Pressure Monitoring System Retail TotalVehicle Base Model ..........................:$ 30935.00 $ 30935.00 50 State Emissions ......................... Daytime Running Lights ..................... 40.00 Front and Rear Clearance Sonar ............. 500.00 SR5 Package ................................ 18" Styled Steel Wheels .................... Tow Mirrors: Power Adjustable, Manually .... 90.00 Extendable, Heated, with Turn Signals ...... Bedliner w/out Deck Rail System ............ 325.00 All Weather Mats ........................... 99.00 --------- --------- Total Accessories ...........................: $ 1054.00 $ 1054.00 Destination Charge ..........................: $ 685.00 TDA .........................................: Gasoline ....................................: Dealer Holdback .............................: Whsl. Financial Reserve .....................: --------- Total .......................................: $ 32674 Plus a Rebate of $3180.00 total $27294.00 |
Jim Barkley Toyota in Asheville NC, offering new and used Toyotas, 2007 Toyota Camry, Camry Hybrid, yaris, FJ Cruiser, and Tundra Jim Barkley Toyota sells Toyota Cars, Trucks, SUVs, and Hybrid vehicles
Here is where I just bought mine from , I live in IN. and this was the lowst price I could find anywhere . |
Just ask for the invoice on the 2008 and pay no more then $700 over that amount. Just bought an 08 5.7L SR5 with 6-inch lift, 20-inch BMF rims sitting on 35's, forward and backup sensor, Predator Step Bars, Rhino Liner, Billet Grill, and Flowmaster exhaust. Dealer was asking 52K and I paid 39K out the door. I meet a kid a few days later who bought the same truck with only the 6-inch lift and rims and tires for asking. Ouch!!!
Good luck!!! |
I'd go with the SR5. Then just add whatever accessories you really want.
08' 5.7L SR5 Black CrewMax w/TRD Post purchase Mods/Upgrades (click on item to view pic) 4-piece Billet Grille Blacked Out Windows and Debadged AFE CAI Borla Dual Catback Backup Camera and Monitor Electrochromatic Mirror Shorty Antenna Projection Halo Headlights |
| Thread Tools | Search this Thread |
