#16 (permalink) |
Give us an update on how that smoker works. That is the same one I was looking at. I like the fact that you can grill on that one as well when needed however I have a gas grill for quick burgers and dogs when needed.
08 Double Cab SR5 5.7 4x4 TRD Pyrite Mica IBTO Mods: Tinted Windows Hurst Shifter Kobalt Narrow Over Rail Tool Box Under Seat Storage Box Toyota Bed Mat HD Trailer Brake Conroller G-Tek Door Sill Protectors International Brotherhood of Tundra Owners Headquarters
#17 (permalink) |
it works too good. disaster struck last night. i smoked it TOO much. the ribs tasted like smoked salmon. the dog ended up eating it all. next time i will only add a few wood chunks in the beginning, and then no more.
#18 (permalink) |
You put your wood and coal in the little burner box on the side right?? It kept the heat in the 220 to 250 range alright??
#19 (permalink) |
yes i did everything correctly as far as i know. its just that it smoked way TOO much. i modified the smoker before i started. the two main mods are recessing the exhaust down to the level of the grates (helps the smoke float around more before getting sucked out and maintains a more even temp) also i added a little shelf like thing that seperates the firebox from the cook box, which points the smoke downward under the meat. i should have only added wood in the beginning and no more, but i kept adding wood for 2 hours.
#20 (permalink) |
So here i pics i just took. I should have done it yesterday when it was brand new and clean, but oh well. As you can see i lowered the exhaust shaft a couple inches. I used aluminum flashing. And you can also see the shelf i added to redirect smoke underneath the cooking grates and to keep direct heat waves from hitting the food closest to the firebox. I used the same aluminum flashing for this. I then spray painted all the things i added with high temperature resistant rust proof spray paint made for grills. The piece of wood you see with the hole is what i use to hold the temperature probe suspended in the air and keep it off the grates.
#21 (permalink) |
Weber rules at my house! Prefer Kingsford self-lighting. I saved all the small stuff(1"-2" dia) from the alders I took down last year. 3 or 4 sticks go onto the coals to 'finish'. Lid: tight, Vents
pen, 5 minutes. yum Best roadkill on the Kitsap Penninsula!! |
#23 (permalink) |
Just head to K-Mart Bill they're on sale there right now! Hahaha!
![]() www.IBTOHQ.com
#26 (permalink) |
Yer laying yer sausage in your baby's rack what?
#27 (permalink) |
Thanks Dez , will do !
#29 (permalink) |
I didn't mean infant!
But yes what a way to end the weekend!
