Tundra Crewmax | Complete Audio System - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 27 (permalink) Old 08-04-2016, 04:02 PM Thread Starter
Supporting Vendor
oemaudioplus's Avatar
Quoted: 12 Post(s)
The OEM Audio Plus Tundra Sound Solution
We are proud to introduce the OEM Audio Plus complete sound solution for the Toyota Tundra Crewmax. The System/Reference Series is designed, engineered and tuned from the ground up to deliver unmatched sound quality, seamless integration and unwavering reliability to discerning Tundra Owners. We not only guarantee the quality and reliability of every OEM Audio Plus sound system, we are confident you will not find a better sound experience for the price.
Quick Links:
Product Page on O+
O+ on Instagram
O+ on Facebook
Installation
The Promise of OEM Audio Plus:
Each O+ System is designed to deliver high fidelity sound reproduction without compromising your vehicle (i.e. space, functionality, integrity or warranty). Our target sound is based on tried and true methods used by high-end audio companies to deliver consistently high sound quality.
Our engineers design solutions that are ideal, simple and tailored for each vehicle. These convictions result in Plug and Play, Drop-In and Ease of Install components (No cutting, splicing, soldering). The moment you plug in your O+ system you will experience our signature sound results (No tinkering necessary).
Features / Specifications:
- Tundra Crewmax specific design and tuning
- D.I.Y. Plug and play installation!
- No splicing, drilling of holes or customization of body panels for installation.
- Optimized for all vehicle factory radios and most aftermarket options
- Vehicle factory warranty remains completely intact when installed according to instructions.
SIGNATURE TUNING
- Tuned exclusively for the vehicle acoustics of the Tundra Crewmax
- Vehicle undergoes of extensive acoustic measuring
- Every component (both stock and O+) is measured to determine the influence of the interior acoustics of the vehicle.
- Objective adjustments only go so far the final O+ sound is only achieved through extensive listening sessions amongst our sound engineers and O+ peers.
- Experience full dynamic sound reproduction from the front woofers without the rattle commonly associated with the factory system.
AMPLIFICATION
8 Channel 32-Bit DSP Power Amplifier
- 360 Watts RMS (Continuous / @ 2-ohms)
- Cirrus-Logic 32-Bit Digital Signal Processing
- Real-time system diagnosis for trouble-free operation
- Meets all OEM standards including AEC-Q100
- OEM grade: reliable performance & operation for the life of your vehicle.
- Programed O+ Signature Sound (Experience unmatched audio the moment you plug it in)
- Clean, unadulterated, undistorted power.
- Mounts using existing hardware locations under passenger side seat (No need to look for a spot to mount your Amp…)
1” FRONT TWEETER
- Designed specific to Tundra for both accurate fitment and superior acoustic reproduction.
- Dramatically enhances music’s clarity and detail
- OEM Grade speaker replacement
- Tweeter utilizes Toyota factory connector.
- Silk soft dome
- 4-ohms
- 50W RMS (100 Peak)
- Sensitivity 91.8 dB (1 W,1M)
- Frequency Response: 3,000-20,000 Hz
- Built-in 6db/Oct. High Pass Filter
- Neodymium Magnet Structure
6 X 9” FRONT WOOFERS
- Engineered specific for the Tundra both accurate fitment and superior acoustic reproduction
- Designed to compliment our 1” Soft Dome Tweeter, The O+ 6 X 9” Woofer provides ever-present bass without impeding vocals.
- OEM Grade Drop-In speaker replacement (same mounting, same connector)
- Carbon Fiber cone material for optimal performance.
- CF is the ideal speaker cone material able to reproduce complex musical passages with a wide dynamic range without inducing distortion even at extreme volume levels.
- 2-ohms
- Sensitivity 90.2 dB (1 W,1M)
- Frequency Response: 50-12,000 Hz
6.5 REAR 2-WAY COAXIAL
- Designed for accurate fitment and superior acoustic reproduction.
- Features O+ 1" Soft-Dome Tweeter
- Carbon Fiber Cone Woofer
- 2-ohms
- Frequency Response: 55-20,000 Hz
QUICK-SYNC WIRING HARNESS
- Connects seamlessly to factory harness and radio
- Constructed of genuine OEM connectors (sourced from Tyco, Sumitomo and Yazaki) to ensure perfect connection and maintain 100% signal integrity every time.
- OEM Fuse Holder Assembly featuring element proof butt-connectors and built-in solder
- Weighs under 4lbs / 1.8kg
SUBWOOFER SYSTEM
- 8" Quad-Coil Woofer
- Genuine Carbon Fiber Cone Woofer
- RMS (200 Peak)
- Sensitivity 88.9dB (1 W,1M)
- Frequency Response: 20-1000 Hz
- Mounts utilizing existing hardware locations behind drivers side seat (no drilling necessary)
- Complete subwoofer system weighs in at
- UniSub 14 Liter Sealed Fiberglass Enclosure
- Powered by our signature DSP Amplification mounted beneath front passenger seat
- Tailored minimalist design: All your vehicle's space, all your music's bass
Compatibility:
• 2014+ Toyota Tundra Crewmax
Price:
System 450Q Retail/MSRP: $1199 (+tax to California Residents)
Reference 450Q Retail/MSRP: $1599 (+tax to California Residents)
Where to buy:
- Direct through O+.com
- 6 Month Financing available through PayPal Credit
Installation
Warranty:
3 year / 36,000 Miles from the date of receipt (operational failure). All components are subject to co-exchange. We stand by the quality and functionality of all O+ systems.
Shipment:
All Tundra Crewmax solutions are made-to-order. Systems typically ship within 7-14 days after order is placed. Reference Series ships using UPS and USPS in the continental US. Alaska, Hawaii, Puerto Rico and any International order will have additional freight charges. Shipping quote available via: shipping@oemaudioplus.com
The Uniqueness of OEM Audio Plus
We are sensitive to the way your car is designed. The Reference 450Q solution is a true OEM-Grade solutions that delivers premium audio the moment you plug it in without compromising the integrity, space or functionality of your Tundra. We don't sell "parts" -- We provide a turn-key sound experience. We only design and offer products that guarantee premium quality, ease of installation and enjoyment ----- We built this product for you! This is OEM Audio Plus.
We welcome and encourage all questions, comments and requests!!
Let us know how we can provide the best experience - Send us a PM, Email experience@oemaudioplus.com or Call us directly at 855-636-6346
Complete Sound Solution for the Toyota Tundra Crewmax
oemaudioplus is offline
The Following 3 Users Say Thank You to oemaudioplus For This Useful Post:
cvargueta (08-05-2016), JoeG (08-05-2016), thatfilipinoguy (08-05-2016)
post #2 of 27 (permalink) Old 08-04-2016, 08:45 PM
Brian20's Avatar
Quoted: 63 Post(s)
Is this for a jbl or non jbl system? If it's for a non jbl, how do the tweeters mount in the front?
Brian20 is offline
The Following User Says Thank You to Brian20 For This Useful Post:
oemaudioplus (08-08-2016)
post #3 of 27 (permalink) Old 08-05-2016, 01:33 PM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
We produce sound solutions for both the non-jbl and jbl equipped Tundra Crewmax
Tweeters are housed in one-piece baffle mounting plate and install using the factory hardware and connector of the front dash speaker (no cutting / no splicing).
You can see the Tweeter installation process in action here: http://bit.ly/TCM-Tweeter
post #4 of 27 (permalink) Old 08-06-2016, 12:48 AM
Quoted: 8 Post(s)
What about us Platinum trim / Entune Premium trucks with 12 speakers?
2014 Toyota Tundra Platinum | Mag Grey | Entune Prem /w Nav
Mods:
LED White Interior | LED Puddle Lights mod | LED Cargo & 3rd & Rev. | ProClip iPhone 6 Mount | Access Vanish Tonneau | K & N Air & Cabin Filter | Air Filter Whistle Fix | Aluminum Oil Filter Cap | Power Lock & Auto Tailgate
memphis2k is offline
The Following User Says Thank You to memphis2k For This Useful Post:
post #5 of 27 (permalink) Old 08-06-2016, 01:59 AM
rdr4evr69's Avatar
Quoted: 53 Post(s)
Ima watch this play out...
rdr4evr69 is offline
The Following User Says Thank You to rdr4evr69 For This Useful Post:
post #6 of 27 (permalink) Old 08-08-2016, 02:29 AM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
We offer a solution specific to the Tundra Trucks equipped with the JBL Audio configuration - because the JBL Audio package is a network system (meaning that the JBL amp controls the function of head unit), it's a different upgrade then we offer for the non-JBL Tundras.
The JUP Kit includes the following:
  • Vehicle-Specific 8" Quad-Coil Subwoofer System
  • Dedicated Subwoofer Amplifier
  • Quick-Sync Wiring Harness
  • Front 1" Soft Dome Tweeter
With this option you would get, our 1-inch soft dome tweeter that offers a sort of "awakening" of the system - resolving the lack of detail and air which is necessary to deliver clarity to the reproduction of the music. We also wake-up the bottom-end by replacing the stock 8-inch paper cone woofer that is powered by two (45w x 2) of the JBL's eight channels with our carbon-fiber cone 8-inch woofer and dedicated 180 watts. Together, they tie-in with the entire system to deliver clean, crisp and clear sound reproduction without compromising the vehicle's functions and its reliability.
The results are improved dynamics and clarity without introducing annoying changes (excessive bass/colored midrange and highs) to the current system. In short, a familiar but very much improved sound quality.
Install Video:
This solution is currently being reimagined - Will create Platinum-specific product showcase thread as soon as finalized.
post #7 of 27 (permalink) Old 08-08-2016, 02:30 AM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
Awesome! Be sure to ask any questions along the way.
post #8 of 27 (permalink) Old 08-14-2016, 07:25 PM
Jayson41's Avatar
Quoted: 23 Post(s)
OP is there a system for a 2013 non jbl crewmax?
Everyone else, anyone install this system yet?
Jayson41 is offline
post #9 of 27 (permalink) Old 08-15-2016, 03:38 PM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
The chasis of the 2013 and 2014 Crewmax are identical we have verified the subwoofer and amplifier mounting for the 2013. The key difference is the disassembly of the vehicle. Though the process is near identical, at this time we don't have instructions that are specific (in terms of pictures/video) to the 2013 Tundra Crewmax.
post #10 of 27 (permalink) Old 08-15-2016, 03:42 PM
Jayson41's Avatar
Quoted: 23 Post(s)
I checked out your Web page and found you guys are in Anaheim, can you pm me a price for install at your shop. If I can keep the factory head unit (non jbl / no nav) that would be ideal.
Jayson41 is offline
The Following User Says Thank You to Jayson41 For This Useful Post:
oemaudioplus (08-15-2016)
post #11 of 27 (permalink) Old 08-15-2016, 03:54 PM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
PM sent. Thank you!!
post #12 of 27 (permalink) Old 09-21-2016, 02:34 PM
Quoted: 9 Post(s)
Install Video:
https://www.youtube.com/watch?v=IQmGKJ51h6c
Will you have / do you have a demo Platinum available to hear the system. I heard the non-jbl system at Formula Drift Long Beach but was more focused on the Tacoma system as I thought, at the time, I would be getting a Tacoma. I ended up with a Tundra but not very impressed with the jbl system. Are you going to be attending any events in So Cal anytime soon?
2016 TOYOTA TUNDRA PLATINUM 4X4
kkim124 is offline
post #13 of 27 (permalink) Old 09-21-2016, 03:26 PM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
We will be attending a few SoCal events, typically at least one a month. We'll be in Ontario this weekend on Saturday at Primal Driven HQ.
We do not have a Platinum Tundra with our "JBL Enhancement" in our fleet, however if you've heard our sound in the past you have a reference to our signature sound reproduction.
What were your thoughts on the Tacoma system you experienced?
post #14 of 27 (permalink) Old 10-04-2016, 01:29 PM
Quoted: 7 Post(s)
Can you pm me an installation quote for the reference system in Anaheim?
2017 CM with premium audio, non-JBL.
Thanks.
hobbs is offline
The Following User Says Thank You to hobbs For This Useful Post:
oemaudioplus (10-04-2016)
post #15 of 27 (permalink) Old 10-04-2016, 02:15 PM Thread Starter
Supporting Vendor
Quoted: 12 Post(s)
PM SENT
  TundraTalk.net - Toyota Tundra Discussion Forum > Supporting Vendors > OEM Audio Plus
