How to install trailer brake controller on 2014 tundra - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 15 (permalink) Old 10-03-2013, 09:46 AM Thread Starter
My new tundra already has pre-wired, how to hook up the brake controller?
happyusa11 is offline
post #2 of 15 (permalink) Old 10-03-2013, 11:53 AM
bobsousley's Avatar
Wire harness in glove box, match up wires and plug it in, took me 5 minutes, hardest part is deciding where to mount since they no longer out that convenient flat spot above that gas pedal on the 14s. I put it there anyway.
2014 double cab, sr5, 5.7ltr.
bobsousley is offline
post #3 of 15 (permalink) Old 10-03-2013, 11:54 AM
bobsousley's Avatar
Plug is above parking brake btw. If you don't have the harness, most RV places will stock it for about 15 bucks.
post #4 of 15 (permalink) Old 10-03-2013, 01:26 PM
kstateskier's Avatar
Quoted: 258 Post(s)
Why doesn't Toyota install an integrated brake controller?
2017 Tundra Crewmax & 2007 Tundra DC SR5, Weatherby Lake, MO
Bilstein 6112 Coilovers Front, TRDPro Reservoir shocks Rear
Coachbuilder +3" Shackles
Firestone Ride Rite Rear Air Bag kit
275/65/20 Toyo Open Country AT2
Advent OEM Nav, Hertz components
TRD Stainless Dual Exhaust
kstateskier is online now
The Following User Says Thank You to kstateskier For This Useful Post:
j_fuggin_t (10-03-2013)
post #5 of 15 (permalink) Old 10-03-2013, 04:43 PM Thread Starter
Thank you for quick reply. I don't think brake controller is that expensive, and you were right, why Toyota doesn't equip with it.
post #6 of 15 (permalink) Old 10-03-2013, 05:32 PM
2010's Avatar
Quoted: 4191 Post(s)
To clarify though, so you don't spend days looking for it. The controller harness is behind the kick panel on the driver side so you will have to remove the kick panel in order to view/access it. Also, it will have a plug in it so you may not think that's the one you need but just remove the plug and insert the harness from the glove box.
2010 is offline
post #7 of 15 (permalink) Old 10-03-2013, 05:34 PM
Quoted: 254 Post(s)
The details to install brake controller are in the owners manual. I think the pigtail is in the lower left kick panel by the parking brake.
I have also seen pictures on the net (don't know where); of brake controllers already installed in the 2014 Tundra. Apparently some companies make a controller that simply replaces a panel on the dash so that it is integrated in the dash?
If I recall correctly the larger panel on the right of the steering wheel that holds three buttons: Park Assist, VSC, and Tow/Haul is "replaced" to make in two levels so the now controller is installed in the dash. This is much like the two tiered panel on the left of the steering wheel holding two rows of controls.
It may have been what I saw was a "pre-production" installation that dealers should be offering in the future?
2014 CM Limited 4x4 FFV
Off Road Pkg
Spray In Liner - Gulf States
KG Steps
JBL Upgraded Entune
Lux Pkg
BigTexTundra is offline
post #8 of 15 (permalink) Old 10-03-2013, 05:36 PM
Supporting Vendor
1ATony's Avatar
Quoted: 77 Post(s)
Welcome to the site
SHOP HERE FOR AWESOME
1ATony is offline
post #9 of 15 (permalink) Old 10-03-2013, 05:38 PM
2010's Avatar
Also, you may not want to mount it under the dash (usually the right side above your right knee) since you may find yourself constantly kicking it with your leg and it is also very difficult to adjust in that position. Here is where I mounted mine as have several others:
2010 is offline
post #10 of 15 (permalink) Old 10-04-2013, 01:15 AM Thread Starter
Thank you very much for the info.
post #11 of 15 (permalink) Old 10-21-2013, 09:51 PM
bench seat option
That looks like a good location for those of you who have the center console (5 seat) arrangement, but i purchased the bench seat so that I can have the option to haul 6 people. There seems to not be a good location for the brake controller. My 2011 had enough room by the dash at teh gas pedal location but the 2014 has a speaker, push button for sway and the knee airbag. Any suggestions?
rcflyertim is offline
post #12 of 15 (permalink) Old 10-21-2013, 10:58 PM
Cruzrtwdgt's Avatar
Quoted: 18 Post(s)
I am 6' 4" and mine is in front of my riggt knee.... I have never hit it. Lotd of options on where to mount, if I was not so lazy I would have mine mounted like the one in the little cubby hole.
13 DC SR5 4x4 TRD 5.7 Super White
TRD Dual Exhaust
2.5" Rough Country level kit
HyperTech Interceptor
2008 Can Am Renegade 800
2014 Harley Davidson FLHTK
09 Tundra TRD DC 4x4(sold)
08 4Runner SR5(sold)
Why yes, I do like Toyota....
Cruzrtwdgt is offline
post #13 of 15 (permalink) Old 10-21-2013, 11:09 PM
Quoted: 155 Post(s)
its a 2014, does it have a cubby that will work?
07 Limited 5.7L 2WD DCRB - billet grille, folding rear seat backs, LED frame strip lamps, BAmuffler, Painted TRD rims, AMP research Bed step
2016 Forest River Surveyor 226RBDS
Tundra Campers Club #35
Ditchhooker is offline
post #14 of 15 (permalink) Old 01-30-2015, 02:32 PM
jeremyers1's Avatar
Did you ever figure out where to put it? I have the exact same front bench seat, and don't see a good place to put the brake controller.
jeremyers1 is offline
post #15 of 15 (permalink) Old 05-13-2015, 01:19 PM
Break control installed and back-up camera went out.
I purchased a electric break for my 2014 tundra and they installed it for me and as soon as they did I lost my back-up camera. Any thoughts on why?
Korben is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Member Area > New Member Introductions
