If you're picky like me, you'll want the Toyota spec grease for your propeller shaft. Dealers don't know what you're talking about and probably just use the general purpose shop grease for everything. (And possibly that's just fine.) PDF showing lube points and recommended lube is attached, see bottom of post.
The grease I found is Mobilgrease XHP 322 Mine. It's an industrial grease that is water resistant and meets Toyota spec for the propeller shaft. Details:
Mobilgrease XHP? Mine Series
http://www.mobilindustrial.com/ind/english/files/sc_grease.pdf
You can order here, $4.8/tube:
(I bought a case)
Mobil XHP 322 | Mobilgrease for Mining & Off-highway Equipment | NLGI 2 Grade
It's available elsewhere too but at something like $13/tube it's more $$ buy it in small quantities.
Pics:
(I bought a case)
Pics:
