Supercharger rattle at idle???? Here is the fix! - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 20 (permalink) Old 10-02-2012, 04:36 AM Thread Starter
Heres the start
After removing the idler pulley, coolant crossover you can remove the 6 bolts holding on the nose section. This is a dry nose supercharger so you do not have to remove oil or re-oil the nose section. The bolts are really hard to get too but it can be done providing you have a selection of extensions and swivels.
There was NO WAY the coupler was going to come out of the SC side so I had to make a puller tool.
How the puller tool works....
http://sphotos-b.xx.fbcdn.net/hphoto...44874218_n.jpg
Hard to tell but the old coupler has egg shaped holes. This slack causes the supercharger to rattle (sounds like rocks are rolling around) at idle. I paid something like 30$ for the new coupler.
The new one does NOT have eased edge holes and will be impossible to align the the units.....Had to take a razor to help the prongs align. This is an operation done 100% blind and you are doing it all from feel. No way to do it without taking some edge out....
New coupler installed!!!!!!
Now just put it all back together!!!! The annoying rattle is gone but its also sounds smoother under boost.....
If your charger is rattling at idle YOU NEED TO FIX IT! Left unfixed it will cause damage to the SC.
Good luck if you try this at home
bingo296 is offline
The Following User Says Thank You to bingo296 For This Useful Post:
Mr. Creosote (10-02-2012)
post #2 of 20 (permalink) Old 10-02-2012, 09:49 AM
How many miles have you gone before this repair?
SRLWOR is offline
The Following 2 Users Say Thank You to SRLWOR For This Useful Post:
Mr. Creosote (10-02-2012), mr.gimixone (11-29-2012)
post #3 of 20 (permalink) Old 11-29-2012, 07:34 PM
mr.gimixone's Avatar
Where did you buy the coupler?
Trd Sport Tundra Super Charged, Ceramic Coated headers, MBRP Dual exhaust, Goodridge Stainless Steel Brake lines, Slotted and Cross drilled rotors, Belltech 441 sp lowering kit, Custom leather, Leer 700 bed cover, pioneer double din raido, kick panel speakers, Air raid spacer, 22" MOMO rims on Nitto 420 tires 75w hid 6000k,BHLM, SMD Tail and Reverse lights 3RD BRAKE LIGHT , ALL interior smds, platinum front door tweeters, critical mass speakers,optimaredtop.
mr.gimixone is offline
The Following User Says Thank You to mr.gimixone For This Useful Post:
Mr. Creosote (11-29-2012)
post #4 of 20 (permalink) Old 07-16-2013, 05:20 PM
TundraSaurus's Avatar
Quoted: 8 Post(s)
So I got the blower rattle ordered the coupler. Will be installing along with the asp pulley. Hopefully all goes smooth.
2008 Crewcab limited, TRD SUPERCHARGED, Magnaflow 12468, ASP Pulley, 12 Jbl Navigation, Powder coated 20'' limited wheels, BHLM, 35w 6000k HID's, LED Tails, TRD sway bar, Hellwig traction springs.
TundraSaurus is offline
The Following User Says Thank You to TundraSaurus For This Useful Post:
Mr. Creosote (07-16-2013)
post #5 of 20 (permalink) Old 07-27-2013, 08:33 PM
Quoted: 8 Post(s)
Did you drain the radiator?
Mr. Creosote (07-27-2013)
post #6 of 20 (permalink) Old 11-24-2013, 05:26 PM
BlaineAtk's Avatar
Quoted: 61 Post(s)
I know this is kind of an old thread but where did you order this part, mine has that weird rattle and how much did it cost. I thought I had a bad bearing or something.....
BlaineAtk is offline
The Following User Says Thank You to BlaineAtk For This Useful Post:
Mr. Creosote (11-24-2013)
post #7 of 20 (permalink) Old 12-18-2013, 07:44 PM
Quoted: 5 Post(s)
This is my 'how to' and was copied verbatim from another site including taking MY images and uploading them somewhere else to repost here without my permission. At least I could of been given given credit.
-This is BS.
~JH
Jonny Hotnuts is offline
The Following User Says Thank You to Jonny Hotnuts For This Useful Post:
Mr. Creosote (12-18-2013)
post #8 of 20 (permalink) Old 12-18-2013, 11:25 PM
SC Tuna's Avatar
Quoted: 156 Post(s)
-This is BS.
~JH
Sorry to hear this. You have link of your post? I need to do this ASAP. Thanks.
SC Tuna is offline
The Following User Says Thank You to SC Tuna For This Useful Post:
post #9 of 20 (permalink) Old 12-19-2013, 12:35 AM
Quoted: 5 Post(s)
Truth is if someone would of mentioned my name or even asked I wouldnt care. Also note how my signature '~JH' was conveniently removed.
~JH
Mr. Creosote (12-19-2013)
post #10 of 20 (permalink) Old 12-19-2013, 12:50 AM
SC Tuna's Avatar
Quoted: 156 Post(s)
~JH
Thanks Jonny. How long did it take you?
SC Tuna is offline
post #11 of 20 (permalink) Old 12-19-2013, 07:58 AM
khoanguyen1983's Avatar
Quoted: 14 Post(s)
Think it said about 12 hrs on his diy
khoanguyen1983 is offline
post #12 of 20 (permalink) Old 12-19-2013, 08:04 AM
SC Tuna's Avatar
Quoted: 156 Post(s)
Just to do the coupler. Can't be right.
SC Tuna is offline
post #13 of 20 (permalink) Old 12-19-2013, 08:20 AM
Quoted: 14 Post(s)
Oh yea, his included pulley change as well
post #14 of 20 (permalink) Old 12-19-2013, 12:37 PM
Quoted: 5 Post(s)
Its one of those things that would take 1/2 the time if I had done one previously. Magnuson was ZERO help!!!
Total time was about 3-4 hours.
Make sure when you are reinstalling the nose that once you get the prongs from the nose mated with the coupler, install all the bolts around the nose with hand torque. Once all the bolt faces are set on the coupler, tighten the bolts one turn only and then do another in a X type pattern. This will insure the nose section is being pulled onto the SC body evenly. Periodically turn the pulley to insure there is no binding.
Also...it is not needed to use high torque to finish the nose bolts. Snug is fine.....just make sure that you do a final check to see if the pulley turns freely after the nose is reinstalled. You should be able to turn the pulley with 2 fingers, any more and you have a misalignment caused by too much torque on one side....loosen the bolts until the nose turns freely and try again.
Good luck
~JH
SC Tuna (12-19-2013)
post #15 of 20 (permalink) Old 12-19-2013, 12:39 PM
Quoted: 5 Post(s)
BTW:
I have about 30K miles on my SC after replacing the coupler with ZERO issues. Its amazing how that stupid piece of plastic can make the SC sound like its coming apart!
~JH
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra DIY's > Maintenance & Repair
If you do not want to register, fill this field only and the name will be used as user name for your post.
