biggest tire size on stock '05
hi guys, im look to put a new set if tires on my 2005 4x4, what is the largest tire i can fit on a stock truck? also, are those 2.5 kits worth it? will it effect my truck as a daily driver?
thanks mike |
Depending on your rim size. 16"=265-75-16. 17"=265-70-17. If you do a 2" lift you can go bigger. Since you are keeping it as daily driver the spacer lift is alright, but if you do serious off-roading then you should look into coilovers. You will need a 4wd diff drop it usually comes with the lift. The spacer lifts will make the ride stiffer, while the coilovers will retain the stock ride quality. Both are great products just depends on how you drive. The biggest difference you'll notice is when you put bigger tires, like say a 285, 295, or bigger.
Stock height 265-75-16 tallest without issues. 2.5" lift in front you can go bigger but you need new rims with different backspacing. The 285's and larger tires on the stock rims will only work with spacers/adapters (they rub on UCA). If you do add the lift you are in luck though, since you have 16's you can get 255-85-16 and they won't rub on the UCA. That is a 33" tall tire. BFG makes it in Mud-Terrain.
I just received my kit from fatbobsgarage.com 3" frt and 2" rear. The kit has nothing but quality parts in it and I would recommend it to anyone considering lifting their daily driver. I willl post pics After I install my kit.
Hey question, i got a 06 tundra with a canuck motor sports spacer, lifted the front 2 3/4 [retty much leveled it with a slight pre runner look (very slight) wut's the biggest i can fit w/out rubbing? and thats on a 17'' rim
#8 (permalink) |
kit:
What and where do you get these spacers? My tire dealer pleaded ignorance when I mentioned them. How do they install?
2005 Tundra TRD ToyTec 3" Lift American Eagle Series 185 Wheels 285/75 R16 Nitto Terra Grapplers De-Badged |
#9 (permalink) |
^ Well if you are going to keep the stock rims then you will need them. Try these places:
Spidertrax (They are sold out currently just keep checking back with them) *They are lug centric and hub centric so install is easier. Hub Centric (Late Model) Marlin Crawler (They are lug centric not hubcentric) *They work fine just have to install carefully and tighten carefully. Marlin Crawler : Heavy Duty Axle Parts and Accessories |
