can anyone tell me if the stock rims (alloy with plastic center caps) have any offset. i want to buy some 17's and put some larger tires than the 265/70/16's. i do have a 3" lift kit on the truck but i don't think a 0 offset enkei sp6 17x8's with 33" tires will clear the upper a arm. anybody know or have a solution...
I just put some 265/75/16 Yokahomas on mine and think if you go bigger you would need the 2 inch blocks for the front springs. I read where 285's will fit with the blocks. My Yoko's look great and are 1.5 taller than the 265/70's that were on it.
#7 (permalink) |
Daystar makes a good spacer you put into your coil over that I just put on my wife 4 runner and it lifted 2.5" and was ony $100.00. Pretty easy to do yourself or shop will charge about an hour of labor.The ride seems to be the same as before too. Other have them too. 4 Wheel parts is where I got hers.
