Hi Everyone, this is my first post on Tundra Talk. Glad to be a part of this forum.
I just purchased a 2001 V8 SR5 Access Cab with 181k miles. The previous owner did the timing belt at 105k. I already did an oil/filter change, air filter, bled brakes, and topped off fluids.
The 180k maintenance is past due and I was thinking I should just replace all the belts, hoses, pumps, and tensioners if I'm gonna do the timing belt. What do you guys think of this kit and are there any other things I should think of doing? Check the spark plugs?
TOYOTA Tundra 4.7L V8 Aisin Water Pump & Timing Belt Kit W/ Hose & Thermostat
