01 Timing Belt Replacement Parts ? - TundraTalk.net - Toyota Tundra Discussion Forum
Old 10-06-2012, 03:55 PM   #1 (permalink)
Jeremy102579's Avatar
Hi guys....I am getting ready to order parts (Genuine Toyota) for changing the timing belt in my 01 limited v8 with 81000 miles.
Besides the belt, water pump, and serp belt what other parts should be changed at same time or are some of these not necassary?
Tensioner Roller? Idler Roller ? Hydraulic Tensioner? Camshaft and crackshaft seals? Thermostat ?
(Southen - Dallas TX) 2001 Toyota Tundra Limited 4x4 78,000 miles STOCK!!
(Southern - Dallas TX) 2000 Honda Civic EX Coupe 5-Speed 108,000 miles STOCK!!
2005 Kawasaki z750s 12,500 miles STOCK!!
DAMN WNY SALT !!!!!
Jeremy102579 is offline   Reply With Quote
Old 10-06-2012, 04:29 PM   #2 (permalink)
Remmy700P's Avatar
While you're in there, do it all (except the crank seal, unless it's leaking). You don't want to have to tear the whole thing apart again for a stupid $30 part. Get the timing belt kit from eBay seller Volkstoy. They have comprehensive kits with quality parts.
2002 Tundra V8 SR5 2WD AC
1C7-Thunder Gray Pearl | Bilstein 5100s | Hellwig EZ-550 Helper Springs
LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 | Josh's Billet Latch Upgrade
Kobalt LP Bed Box | Ham Radio: KJ6OPA | CB Radio: Midland 75-822
Remmy700P is offline   Reply With Quote
Old 10-06-2012, 04:29 PM   #3 (permalink)
Not trying to give you any hope but When I had my '01 I changed the timing belt 3 times around 75k interval and my water pump and other seals and rollers at 150k. the belt tensioner roller I changed twice. I sold my truck at 285k miles Im sure it still had a lot of life left. No leaks. All I would suggest is to keep up on your maintenance especially what you are doing wouldn't hurt.
pointcrossed is offline   Reply With Quote
Old 10-15-2012, 08:47 PM   #4 (permalink)
What's a comprehensive kit ?
DAMN WNY SALT !!!!!
Old 10-20-2012, 09:38 AM   #5 (permalink)
It has what you need for the job and folks that use the kit say good things about the quality of the parts included.
2000 Tundra Supercharged 4.7 TRD 4x4 in Red Pearl.
For pics of mods on my Toy, check out my cardomain location.
My cardomain location:
http://www.cardomain.com/ride/665303
jbtoy1 is offline   Reply With Quote
HTML code is On
