4.7 Oil Seepage or Leak - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 7 (permalink) Old 02-08-2017, 11:14 PM Thread Starter
Hi everyone
I am getting prepared to replace the timing belt on my 2006 Tundra Double Cab very soon. I was checking out the engine and I noticed some oil behind the timing covers. Would this be a possible cam seal leak or valve cover leak? The following pictures show the leak on both the drivers side, and the passengers side near the power steering pump. I wanted to make sure I have all the correct parts on hand before I tackle this job. I am a weekend mechanic, but have sucessfuly changed a timing belt on an 2004 Acura MDX. Thanks for you help with this!
When changing the timing belt, I was planning on replacing the timing belt, tensioner, pulleys, water pump, thermostat, radiator upper and lower hoses, as replace the coolant. I was also planning on changing spark plugs. Did I miss anything?
Thanks!
Nathan
sheerrocko is offline
post #2 of 7 (permalink) Old 02-08-2017, 11:27 PM
Powertechn2's Avatar
Quoted: 1158 Post(s)
Looks like a light seep.
Can't really say I would worry about it, not wet, not dripping.
and you can call me Power.
Powertechn2 is offline
post #3 of 7 (permalink) Old 02-08-2017, 11:38 PM Thread Starter
Thanks Powertechn2!
Do you think I need to have the cam seals on hand when I tackle the timing belt, or do you think it is coming from the valve cover?
The Following User Says Thank You to sheerrocko For This Useful Post:
Powertechn2 (02-09-2017)
post #4 of 7 (permalink) Old 02-09-2017, 12:21 AM
I have never been into a 4.7. So I can't honestly say.
But in general, the way I look at things is like this.
A. Try to have everything you might possibly need on hand.
B. Try to have everything you shouldn't need on hand.
C. Fix everything you can while you are almost all the way there as you are almost all the way there.
Only exception is crazy ladies.
There is no fixing everything, just do what you can, and deal with the rest later...
Sorry, it is a moonshine night. But other than the exception, all else is true. And even the exception, just it doesn't apply here.
post #5 of 7 (permalink) Old 02-09-2017, 12:24 AM
My Password is 1234
fka MBD's Avatar
Quoted: 2441 Post(s)
D. have more beer then you will think you need plus extra and then some
fka MBD is offline
The Following User Says Thank You to fka MBD For This Useful Post:
post #6 of 7 (permalink) Old 02-09-2017, 10:52 AM Thread Starter
Bahahaha
Thanks, I will keep that in mind. I guess I better order the cam seals, crank seals, and valve cover gaskets just in case. If anyone has any experience with the 4.7, please keep me posted.
post #7 of 7 (permalink) Old 02-28-2017, 11:49 AM
SethNautique's Avatar
Quoted: 137 Post(s)
Ive got the same seepage on the driver side and I cant really tell from your passenger side photo but ive got a little leak there as well. I just replaced the passenger side valve cover gasket and that seems to have stopped the small leak I could see dripping from the valve cover but I also think the cam seals are leaking on mine and yours.
I dont think you would see the oil residue on the bottom of the timing cover if it were a valve cover leak. Due to driving, oil tends to migrate towards the cab because of air blowing through. I dont think you would see the oil migrating forward with a valve cover leak.
My water pump is leaking so it looks like its time to tear it down and find out. How many miles do you have on your truck? Im at 260k, so leaking cam seals doesnt seem out of the ordinary.
2005 DC 4x4
Fox 2.5's front/ 2.0 rear
TC UCA
Falken AT3 265/75/16
SethNautique is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra General Discussion > 4.7 discussions
